Sign-in / Sign-up
Solved
ASRock P67 Extreme 4...Please Help.
  • Motherboards
  • BIOS
June 7, 2011 8:14:45 PM
I have finally installed my components and ran my BIOS. :D
I was just wondering, is it normal on the new UEFI BIOS for the mouse's physical up and down strokes register in the opposite direction?
Like if i pull the mouse down, the cursor will go up. :heink:
is this a sign of a problem? or is it just the default settings?
thanks a lot you guys,
Jon
More about : asrock p67 extreme
June 8, 2011 3:56:13 PM
That's weird..lol. Try disconnecting the mouse after shutdown and boot up again.
m
l
Best solution
a b V Motherboard
June 8, 2011 4:49:06 PM
I recommend the following:
1) Unplug the computer; hold power button for two seconds to discharge remaining energy in board/PSU capacitors
2) Clear the CMOS
3) Boot the computer and check again
I know it sounds like a simplistic procedure, but it's solved weirder behavior than the mouse thing you've mentioned.
I would also recommend trying another mouse -- no way ASRock lets this kind of bug get past. I'm sure they test this with standard mouses -- it's possible you have an unusual mouse that the BIOS is having trouble with.
June 18, 2011 10:57:22 PM
Best answer selected by ReliJon.
m
l
