hi all, second time building a system here...figured this would be the best place to come for advice
APPROXIMATE PURCHASE DATE: within 2 weeks
BUDGET RANGE: Around 2k, nothing exact though
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: work, gaming
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS, disc drives, sound card
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, tigerdirect.com, amazon.com in that order
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: open minded to all suggestions
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1200
ADDITIONAL COMMENTS: am very open minded to upgrading or downgrading if the suggestion makes sense (i.e. would get a worse graphics card if the price differential was great enough)
Here are the parts I have decided on so far:
Case: Cooler Master HAF X
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225&cm_re=haf_x-_-11-119-225-_-Product
Mobo: EVGA X58 series
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188065&cm_re=x58-_-13-188-065-_-Product
CPU: i7 Quad @ 2.8
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
Ram: CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model TR3X6G1600C8 G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145236
Video Card: ATI Radeon HD 5970
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131324&cm_re=5970-_-14-131-324-_-Product
SSD: Intel X25-M Mainstream SSDSA2M080G2XX 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD) - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167027
PSU: Rosewill 1000w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182188
things i already have:
fatality sound card
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102019
aftermarket heatsink
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010&Tpk=corsair%20h50
i also intend to set up another hard drive as my storage hard drive, with the ssd as my operating drive. did i miss anything? all comments, suggestions, death threats, etc. are welcomed
OVERCLOCKING: Yes
CPU: i7 Quad @ 2.8
PSU: Rosewill 1000w
fatality sound card
