G
Guest
Guest
Hi All,
I am planning to build a gaming rig for myself finally. I have chosen most components after much research/deliberation, and hope it works well together. Plan is to build on this build bit by bit in the future.
I am looking for your inputs/suggestions so i can move on to actually ordering the stuff.
S.No Component Spec Link % Cost
1 MoBo Asrock 890GX Extreme3 http://www.newegg.com/Product/Product.aspx?item=N82E16813157188&cm_re=Asrock_890GX_Extreme3-_-13-157-188-_-Product
2 CPU AMD Phenom II X3 720 Black Edition http://www.newegg.com/Product/Product.aspx?Item=N82E16819103652&Tpk=AMD%20Phenom%20II%20X3%20720%20Black%20Edition
3 RAM GeIL GV3 4GB 1333 C9DC
4 Video 1GB HD4670 http://www.newegg.com/Product/Product.aspx?Item=N82E16814150450&cm_re=HD4670-_-14-150-450-_-Product
5 Case Cooler Master Storm Scout ATX http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196&cm_re=Cooler_Master_Storm_Scout_ATX-_-11-119-196-_-Product
6 PSU
[strike]7 CPU cooler to be bought later.[/strike]
8 HDD Samsung Spinpoint F3 HD502HJ, 500GB http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181&Tpk=Samsung%20Spinpoint%20F3%20HD502HJ,%20500GB
9 Optical LG GH 24 NS Black
10 WI-fi
My questions/doubts are the folowing :
1. PSU - what sort of PSU should i go for in terms of rating ? 400-550w ? budget of 60-70eurs
2. GPU - should i go for 2x512mb CF or 1x1gb ? eithre choice within a max budget of 100-110euros
3. Wi-fi - what kind of card should i go for here ?
4. ASrock 890gx Mobo, what is your opinion on this choice. I read a few reviews about it not POSTing.
5. The case is one i have selected based on the budget and reviews. Do let me know if you think there are better ones in the price range of 60-70 euros.
Looking forward to hearing from all of you out there. God knows i need the help.
Cheers
Paul
6 PSU
10 WI-fi
Cheers
Paul
