Hi, I've just bought myself a new powercolour hd5830. It requires a dual 6 pin connector for power. My system has an available 6 pin connector cable sourced directly from the PSU and from this cable, there is an extension for another 6 pin connector. The question is, should i connect both of the 6 pin connector to my GPU or should i use another 6 pin connector which is source directly from the PSU? I asked this as i was told that connecting a 6 pin connector which is an extension of the 1st 6 pin connector may caused the GPU to be underpowered and thus underperformed.
Any thoughts are welcome. I understand this sounds a little complicated, but i hope you experts can understand me. Thanks
