Sign-in / Sign-up
PC won't boot, power light is off and CPU fan is at max.
  • Prebuilt
  • Computer
  • CPUs
  • Power
  • Systems
Last response: in Systems
August 9, 2010 9:50:20 PM
I've read this thread :
http://www.tomshardware.com/forum/252854-31-boot-fans-s...
But the tips in there didn't fix my problem.
Computer will end up booting after I unplug it, wait, plug it back on and try again (many times).
So yeah the power light is OFF, the CPU fan turns at maximum speed and power supply fan seems to be turning at normal speed. Computer doesn't beep at all.
I tried resetting the CMOS, checked to see if the CPU is seated correctly and everything was fine.
More about : boot power light cpu fan max
a c 173 à CPUs
August 10, 2010 6:39:40 PM
I suspect that you have a problem with the standby power supply inside your PSU.
m
l
August 10, 2010 8:50:58 PM
I should try with another power supply? I'll try that!
m
l
August 20, 2010 11:37:07 AM
I actually had the same issue with my pc,CPU may not be supported by your motherboard go to the site and double check
m
l
