Hello,
I put a machine together from a Komplett Kit back early in the year. I got a Gigabyte GA-EX58-UD5, i7-920, Crosshair Ram, Harddrive, PS, Case..etc.
All was working fine until today. I've just wiped the HD and put on XPSP3. Today the computer started fine and I installed WMP11 during a regular update. When the computer restarted it froze just after Verifying DMI Pool Data... Boot From CD/DVD. If I try boot from the XP CD I get to the "press any key to boot from CD" and it still freezes, did get to hit enter once but the machine froze.
I do have images of my machine taken using NovaBackup. Using the Nova rescue disk I can see that both the Hard drives are not being picked up. But are listed in the BIOS. I have an external USB HD that is registering as the C: drive.
Ive tried taking out all ram but one stick - Same Problem.
Bios back to Fail Safe Defaults - Same Problem
Removed all USB Devices - Same Problem
Using Q-Flash the computer also freezes. Can get to it from the Bios setup but only lists Floppy Drive.
Any ideas?? Is it the MB?
Hop someone can help!!!
Thanks,
Paul.
Thanks,
Paul.
