Asus a7s8x-mx sound problem
hi all newbie here :)
having a sound problem with my asus a7s8x-mx, check the manufacturers website and downloaded the drivers which says are all installed but im still getting no sound and close to pulling my hair out :)
hope sum1 can help and thanks in advance
1 answer Last reply
More about asus a7s8x sound problem
  1. problem solved
    They are jumpers marked FP_AUDIO in the bottom left corner of the board.
    should look something like this
    123 4 (pin missing between 3 and 4 on this line)
    56789
    There should be a jumper over 3&7 and 4&9
    :) hope this helps if any1 else is having trouble
Sound Cards Asus Drivers Components
