Pls Pls Help!!! No Audio device detected on laptop. Think its hardware???
  • Sound Cards
  • Audio
  • Devices
  • Components
Last response: in Components
October 19, 2010 4:14:10 PM
Hello,
I am having trouble with my hp tx2000, in the sys tray of windows 7 I am getting no audio device installed, I have tried xp, vista, 7 and even linux.And none of them are seeing the sound card. I have no sound properties in the device manager either.
I am starting to think its a hardware problem and not driver related. As far as I can tell from using everest it shows the south bridge as being an nVIDIA nForce 430 (MCP51) - High Definition Audio Controller
Any help would greatly be appriciated, I failing getting this to work I am going to solder a small usb soundcard inside, but I would rather, fix this right.
Thanks
More about : pls pls audio device detected laptop hardware
October 21, 2010 8:35:19 PM
Hello, and welcome to the Forum.
What you should possibly do is contact HP.
