N68S7AA Multiplier Problem
I've got a problem with setting the ratio cmos setting aka multiplier. I'm running an X6800 cpu. When I go to the setting the value is stuck at 60. Nothing I've tried will let me change the value. I know Foxconn has some ill defined ways of working with bios through the Fox 1 Chipset but I've enabled and disabled settings nothing moves that value. I was wondering if clearing cmos might enable the setting.
Any help is greatly appreciated.
2 answers Last reply
More about n68s7aa multiplier problem
  1. After testing Foxconn determined it was a bios related problem. Since the board is EOL there is no fix. I give them credit for spending some effort on an obsolete board.
  2. Best answer is the one I added. Since you can't select your own for best answer
    please make adjustment necessary so I don't keep getting "Best Answer" EMail
    requests.
Foxconn CMOS Motherboards
