Yes, that is how the system manages to keep the CPU relatively cool. I assume you are referring to the fan on the CPU heatsink, is that correct? Are you using a stock, OEM HSF with your CPU? If so, you might want a more effcient and effective aftermarket HSF. Just something to think about.
