Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Dx 11 pci sound card
Forum CPU & Components : Sound Cards Dx 11 pci sound card
Hello,
i have a acer aspire sa 90 and a gtx 460 and every thing other than my sound card has been upgraded so now i have only 3 pci slots left please suggest me a good sound card budget is not an issue
Reply to vada
My soundcard recommendations:
HT Omega Striker, ASUS Xonar D1/DX. Auzentech Forte, ASUS Essence ST/STX
------------------------------ http://valid.canardpc.com/cache/banner/1647132.png
Reply to gamerk316
thanks for the quick reply but asus xonar d1/dx uses pci-e as well as auzentech forte and asus essence st/stx the only one which uses pci is ht omega striker i would like some more choices pls tel me and it should be dx 11 compatible and i dont think the omega is!
Reply to vada
No, stay away from Creative; why bother with the loss in audio quality? Nevermind the historic issues that plauge Creative's PCI lineup (mainly "Snap, Crackle, Pop" ). The only Creative card worth considering is the Titanium, and that card is beaten feature and quality wise by cards $20 cheaper.
The ASUS Xonar D1 is PCI; the newer DX is PCI-E. You could also make a case for stepping up to the ASUS Xonar D2 or Auzentech Prelude if you need a more capable PCI card, but both are currently at REALLY bad price points in my mind...The Essence ST is overkill, and the Creative ExtremeAudio is a cripple (many disabled features and very low quality audio).
Also, soundcards have nothing to do with DirectX.
Reply to gamerk316
2 189281,5,338029]No, stay away from Creative; why bother with the loss in audio quality? Nevermind the historic issues that plauge Creative's PCI lineup (mainly "Snap, Crackle, Pop" ). The only Creative card worth considering is the Titanium, and that card is beaten feature and quality wise by cards $20 cheaper.
Also, soundcards have nothing to do with DirectX.[/quotemsg]
then why is it that many games like bfbc2 have dx 10 capable sound cards in recomennded ? and is there a sound card that uses 2 pci ports to give better sound quality? AND does the d1 use pci-x cos it dosent look like a pci tome or is it a pci2? and if it is a pci 2 then is it backward compatible with a pci1
and is the Creative Sound Blaster 5.1 VX i really dont care much about quality just dont want breaks in sound when playing about with the latest games and im only using a 2.1 speaker set-up as i dont have room for a 7.1
Message quoted 1 times
Message edited by vada on 10-21-2010 at 04:49:11 PM
Reply to vada
vada wrote :
2 189281,5,338029]i really dont care much about quality just dont want breaks in sound when playing about with the latest games and im only using a 2.1 speaker set-up as i dont have room for a 7.1
If you don't care about sound quality, why bother upgrading your sound card? Just stick with your onboard audio.
Reply to thefivetheory
Quote :
They don't. They recommend DX10 VIDEO cards, but never sound cards. Pretty much every sound device in existence works in Vista/7, provided they have drivers.
Quote :
No, and using two PCI slots would do nothing to improve quality even if you could hook a device up that way.
Quote :
The Xonar D1 is PCI.
Reply to gamerk316
yea well gamerk thanks for the clarification ive got the xonar d1 and its a good card i dont regret it my only confusion was why then does bfbc2 recommend dx 10capable sound cards i still dont get it i have the box and im reading it right now the minimum says dx capable cound cards and the recommended says dx10capable sound cards
Message edited by vada on 10-23-2010 at 05:31:16 AM
Reply to vada
What kind of speakers do you have, you would prob see a bigger benefit in sound quality by upgrading them. Sound cards are meant for a very narrow portion of PC owners
Reply to etk
im running a creative 2.1 setup and have a realtek onboard that supports 7.1 but i just wanna know is my card dx 10 ready? and i thnk having a sound card will benefit me
Reply to vada
There are 2072 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 6 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
