So I'm starting my first intel build this weekend so I had a few questions. First my specs are
Intel core I7 950
Asus rampage III formula
Corsair XMS3 1333 6gb triple channel
Sapphire 5970 2gb using eyefinity3
Samsung 23" x3 monitors @ 5760x1080 res
WD caviar black 1tb
Corsair hx850 watt
Antec 1200 case
Possilbly picking up a cm v6gt HSF
I will NOT be overclocking for awhile at least till the new wears off lol
Ok question 1: what is the stock voltage I set in the bios for the i7 950
I know theirs an auto voltage feature but with my amd 955,cmy old mobo would set it way too high for stock speeds so I dont trust it. Old mb was a asus m3a78-t in case your wondering
Question 2: since I'm using 1333 ram and my mobo runs native 1066/1333 will I have to manually set my voltage and timings for them. I bought this ram specifically because it runs at 1.50v instead of 1.65v.
Question 3: are there any settings that are similar to AMD cool n' quiet that would throttle the i7 that I should turn off?
This rig is purly for gaming If that makes any difference with Q.3. Thank you very much for any info on this.
Intel core I7 950
WD caviar black 1tb
Corsair hx850 watt
Antec 1200 case
