Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > [Solved] Help with $650 gaming machine
Forum Systems : New Build [Solved] Help with $650 gaming machine
Best answer from Proximon.
APPROXIMATE PURCHASE DATE: this week
BUDGET RANGE: $650
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming
PARTS NOT REQUIRED: keyboard, mouse, speakers, monitor (will buy 22" monitor later)
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, ewiz.com, tigerdirect.com
COUNTRY OF ORIGIN: US
PARTS PREFERENCES: Need video card to run SW The Old Republic, SC2, Mass Effect 3 when it comes out
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: I want my video card to produce above games at 1920 x 1200, or 1920 x 1080 at highest settings on 22" monitor
ADDITIONAL COMMENTS: I've purchased a few parts already. They are:
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
http://www.newegg.com/Product/Prod [...] -_-Product
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C9
http://www.newegg.com/Product/Prod [...] 6820145260
MSI 870-G45 AM3 AMD 870 ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813130290
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811147153
Here we go:
I'm sort of on a budget. Perhaps I shouldn't have gotten the 955 deneb CPU, but I wanted it. I want to be able to run games (SWTOR when it comes out, SC2, COD Black Ops) at high frame rates on one monitor, 22" or so.
I'm debating getting a Radeon 5750 1GB 128-Bit video card, but not sure if this will give me the desired results above. Will it? I've also considered upgrading to a 5770 1GB Juniper, but this is a little pricey, puts me over budget. But if this is what is needed to get the desired performance, I'll buy it.
Lastly, I could crossfire 2 5750s on my motherboard, but my mobo is 16x / 4x. I wanted 16 / 8 but this motherboard was $60. I know performance wise it would take a hit, but I also know from other threads here the hit is not that big. I could also buy one 5770 with the intention of adding another this spring to crossfire the two of them, but for only one 22" monitor is that overkill? I just want high resolution (19xx x 10/12xx or 25xx x whatever) gaming at high fps on one screen. What graphics card (or crossfire) will do what I need it to, and not less than I need it to?
Last question,
According to newegg.com's PSU calculator with the above specs and 5750s crossfired I only need 510W of PSU. I already have a 530W. I know if I go the crossfire 5770s I need to upgrade. Otherwise I've been planning on purchasing a PSU. Input there?
Thank you so much!
Message edited by my92agsr on 08-12-2010 at 01:03:02 AM
Reply to my92agsr
See the PSU guide in my sig please.
As to the GPU, I think you should get ONE and either a GTX 460 or a 5850. Both are good price/performance ratios and the best deal given your MB.
ME2 and SWOTOR will run just fine, max settings, on a single GTX 460 at 19x10. The 5850 would probably keep you happy longer though.
------------------------------ Waiting for an answer? I lost the flag to the post. Send a PM
My Guide to choosing parts
Troubleshooting Guide
PSU Guide
Reply to Proximon
Is a GTX 465 better or worse than a 460? This is a deal on newegg this month:
ASUS ENGTX465/2DI/1GD5 GeForce GTX 465 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Prod [...] 043X499650
After rebate and coupon code it comes out to $198
This TX or 5850 kills my budget, oh well, should have budgeted more.
Reply to my92agsr
GTX 465 is worse, older hotter design. Not a good performer. It's GTX 460 or GTX 470... but the 470 is hot also. Good benchmarks but hot.
Get the GTX 460.
PSU Guide
Reply to Proximon
Do you think a 5770 would outdate itself too fast? Or would it even run SWTOR at highest res?
Reply to my92agsr
If you bought one counting on adding a second later I think you might be too late.
If you did get one I would recommend getting a 22" monitor at 1680x1050 instead.
http://www.newegg.com/Product/Prod [...] 6824179051
That would help... shop locally for a monitor when possible.
PSU Guide
Reply to Proximon
would a 460 with only 768MB RAM support the original higher rez of 1900 x whatever?
this one perhaps?
http://www.newegg.com/Product/Prod [...] 6814125334
Reply to my92agsr
Best answer
I think that 1GB should be a minimum now. The benchmarks I have seen confirm that.
If you use the promo code "PREPPY", according to this thread:
http://hardforum.com/showthread.php?t=1538838
Then this Zotac is $210
http://www.ewiz.com/detail.php?nam [...] -Card&c=CJ
PSU Guide
Reply to Proximon
There are 2065 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 1 hour ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
