Solved
Help choosing SSD for upgrade
Hello all,
I want to eventually upgrade my system to a SSD as I've heard they can improve overall speed. I currently have a WD 1TB Caviar Blue HDD and need some help deciding on which SSD I can buy.
As far as storage goes, I won't need a ton, just enough to install Windows and a few programs like Lightroom, Photoshop, Premiere and After Effects CS6 and use the HDD as well as my external HDDs for all data storage.
I'm looking at three SSDs and don't really know what I should be looking for exactly, mostly with Max Sequential Read/Write as well as Random Read/Write speed.
Samsung 830 Series 256GB
Samsung 830 Series 128GB
Intel 520 Cherryville 180GB
Any and all help with my decision would be greatly appreciated and if needed, I can always give more info.
Thanks
5 answers Last reply Best Answer
More about help choosing upgrade
  1. Anyone else?
  2. Best answer
    I recommend the Samsung 830 ssd. It has a stellar track record that is hard to beat. The Cucial m4 is another popular ssd worth considering.
    I maintain the ssd database listed in the sticky at the very top of this ssd forum section. Here is the link:
    http://www.johnnylucky.org/data-storage/ssd-database.html
    Scroll down to the brands and models you are interested in and follow the links to the technical reviews.
  3. Sounds like I'll be looking into the 830. Thanks all!
  4. Best answer selected by codycrazybull.
    I guess sandforce claims lower power consumption than any other controller.check this link http://www.prnewswire.com/news-releases/lsi-sandforce-flash-storage-processors-enable-lower-power-and-higher-performance-for-ultrabook-manufacturers-164413836.html. But Sandforce is not a bad drive - it might be slightly slow on incompressible data but i sure havnt faced much problems with my intel 520.
SSD Hard Drives Western Digital Storage Product
