Yes No
Ads
Tom's Hardware > Forum > Systems > Prebuilt > Dell dimension 4550 power supply, fan, etc.
Forum Systems : Prebuilt Dell dimension 4550 power supply, fan, etc.
Hello,
I have an 8 year old Dell Dim. 4550. A fan went out a while back. Then recently, it stopped recognizing the 2nd internal hard drive. Then one night it froze up. I left it alone overnight, still frozen in the morning. Turned it off. Went to turn it on and it wouldn't. My external drive light has done nothing but flash since. Wondering now if I need to replace the power supply and which one to get? Need to know which replacement fan to look for also. Don't know if it's worth repairing, replacing parts, etc.. Mainly concerned with recovering data on the two internal hard drives, and the external hard drive, and how to do it. UGH! The external hard drive was my backup. Hooked it up to another computer, and it is not recognized. Don't know what to do or how. Thanks in advance for any tips or advice!
Reply to gnl
Physically pull the internal drives, jumper each as "Master, No slave". Connect them, one at a time to an IDE cable, then boot and copy the files to another hard drive.
Reply to jsc
There are 2067 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 1 hour ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
