Lights of flash drive blinks but drive not working.
Last response: in Storage
- USB flash drive Continuously Blinking RED light? solution
- Flash drive wont work on my Vista loaded computer. Flash drive light comes on when inserted into usb port but the computer do solution
- Nor my computer nor my tv can detect my hard drive. The light on the hard drive that always blinks still blinks so it's not br solution
- Cd drive audible clicks when light blinks Forum
- SolvedUSB Flash Drive not working in Windows 7 PC (But works in another Win7 Machine) solution
- SolvedFlash Drive worked fine last week, not working today solution
- SolvedFlash Drive not Working solution
- SolvedSystems supports 2gb flash drive but 16gb is working. (did not used to work and ive done nothing to the system) solution
- SolvedBootable USB Flash drive - Menu not working. solution
- USB Flash Drive Suddenly "Empty" -- Windows sees it, says working properly, but can't access it. solution
- flash drive light on appears only in disk management solution
- SolvedMy flash drive doesn't work solution
- Wireless Keyboard and Mouse Freezes (almost stops from working) while Using Flash Drive solution
- SolvedI use the Lexor 8G flash drive. Had it for quite a while and at some point swapped it from my Toshiba laptop to a MAC. It work solution
- my lexar flash drive is not working (I have a macbook air laptop) solution
- Solved4 GB Cruzer Flash Drive. It works in my netbook but not my desk top window 7 solution
- I have one USB flash drive I can't read, if I plugged another USB flash Drive working well solution
- SolvedMy USB flash drive won't work on any computer! solution
- usb flash drive not working solution
- Flash Drive Stopped Working, Undetected solution
- More resources
Read discussions in other Storage categories
