Odd cd-rom problem
Hello,
I'm working on a Dell optiplx gx280 and the cd-rom will not open. It makes a sound like the tray wants to open but it seems it lacks the juice. I swapped the stock cd-rom with a different one thinking it was a shot drive, and the same problem occured. I'm perplexed. I reseated all connections and the problem persists. Any ideas?
Thanks
3 answers Last reply
More about problem
  1. I don't know why it should happen with two different drives unless the power supply voltage is down -- but you'd notice other symptoms more serious than this.
    Assuming the second drive is the same model as the first:
    Could be belt slippage or the puck (probably magnetic) is sticking to the drive hub.
    Clean the belt.
    The puck issue can be fixed with a layer of adhesive tape.
  2. Thanks for the quick reply, but the problem persists with two seperate cd-rom drives. It seems unlikely to me it could be something internal on the respective cd-roms.
  3. Sorry my revised answer attempts to address that (I misread your post originally).
Prebuilt Dell CD-Rom Systems
