G
Guest
Guest
Hello,
here is the situation, running both windows xp and 7, Bios only visible if I unplug power supply and vga monitor cable and turn on psu and computer and then plug in vga cable after the computer is on, then I can see my options to dual boot etc...
For some reason the BIOS was changed to boot from pci and not pci-e. I tried changing it and saved it but I still get flashing power button on smasung lcd monitor when I run the dvi cable, problem is my radeon video card is dvi only. vga to dvi does not make a difference on the video card, seems only onboard is working right now, my friend checked my video card and it ran fine in his computer.
Please help.
Please help.
