Hello,
I had been having some memory problems, so I RMAed my 2x OCZ ddr3 2gb 1333MHz ram and got 1600MHz RAM instead. I put this in my PC and booted up. Immediately my computer crashed with a memory-related bluescreen. I ran mtest86+ and got a bunch of errors at somewhere between 2000MB-3000MB. I did some swapping and discovered that it seemed neither new stick of RAM was "bad". There are 4 slots for RAM in my motherboard. The one closest to the CPU is pretty much blocked by the CPU fan. When either stick of RAM is in the next slot, I get no errors on memtest x86+. When either stick of ram is in the next slot, I get errors at ~2500MB. In the 4th slot, I get errors somewhere around 3000mb. I noticed all of the error byte columns are the same-0x00400000. Since there is only one bit off, I think there is one tiny wire that is damaged in the motherboard. Is there anything I can or should do besides RMA the motherboard?
Thanks in advance!
Thanks in advance!
