CPU HT speed
Ive just put a Athlon II X2 260 into an Asus M2N68-CM with the latest bios update. Im not too sure exactly where the problem lies but shouldnt I be getting HT speeds of 2000MHz instead of the 1k I getting (see link for pic I cant seem to get it to show directly) or is this a restriction placed by the MB. If anyone has any idea or can point me in the right direction that would be great.
http://img197.imageshack.us/i/cpucz.jpg/
2 answers Last reply
More about speed
  1. You are getting the right speed, CPU-Z shows you the bus frequency, the bus is dual pumped like DDR so you get 2000 megatransfers per second, which is the max your board supports.
  2. Excellent thanks for clearing that up
CPUs Asus
