Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > HD 5770. Enough power supply?
Forum CPU & Components : Power Supplies, Cases & Mods HD 5770. Enough power supply?
Gonna buy this for verry cheap price. So am asking is this PC power supply is enough for my old video card HD 5770 http://img638.imageshack.us/img638/1538/21922781.jpg
PSU installed internal
http://img442.imageshack.us/img442 [...] 2f44d6.jpg
Won't be a problem running system like this?
Reply to fiigaro
30 amps on the 12v rail is plenty for the 5770.
Reply to o1die
you should be fine, the ATI 5770 is very power efficient
------------------------------ defeating idiot fan boys since 2008.
Reply to ct1615
I have a similar problem, so I'll post it here instead of starting a new thread. I just bought a Powercolor 5770 and an Antec TP 750w power supply, but I'm not sure if this is an appropriate PSU to run this graphics card. According to the graphics card guide on this website (http://www.tomshardware.com/forum/279391-28-power-requirements-specs-popular-graphic-cards-guidea) the 5770 needs at least 30 amps on the 12v rail, and ideally should have 38 amps. The trouble is my PSU only has 25 amps on each 12v rail, and the graphics card has only a single 6 pin power connector. Am I misunderstanding this or is do I really need to get a different PSU?
Reply to dermal_plating
those are the ATI recommendations and totally useless. They are listed to cover crap PSU people buy for $20. the antec truepower series are very good PSU. your antec has 62a on the 12v rail, more then enough for the ATI 5770, in fact more then enough for four of them.
a system with with the ATI 5770 needs a decent 400w unit with 22a on the 12v. the following system below won't even break 300w with the ATI 5770 during a stress test
Core i7 Test System Specs
- Intel Core i7 965 Extreme Edition (Overclocked @ 3.70GHz)
- x3 2GB G.Skill DDR3 PC3-12800 (CAS 9-9-9-24)
- Asus P6T Deluxe (Intel X58)
http://static.techspot.com/articles-info/209/bench/Power.png
Reply to ct1615
Thank you ct1615, your help is very much appreciated. I am still confused by the whole 12v rail thing, I'd assumed that a 6 pin connector from this PSU could only supply 25 amps due to each of the four 12v rails being rated at only 25 amps. So really each of those rails can supply the PSU's maximum total amps?
I can understand your confusion, what you really have is a single 12v rail that has been split 4x, not four 12v rails. hopefully this helps you out.
What is "multiple +12V rails", really?
In most cases, multiple +12V rails are actually just a single +12V source just split up into multiple +12V outputs each with a limited output capability.
There are a few units that actually have two +12V sources, but these are typically very high output power supplies. And in most cases these multiple +12V outputs are split up again to form a total of four, five or six +12V rails for even better safety. To be clear: These REAL multiple +12V rail units are very rare and are all 1000W+ units (Enermax Galaxy, Topower/Tagan "Dual Engine", Thermaltake Tough Power 1000W & 1200W, for example.)
In some cases, the two +12V rail outputs are actually combined to create one large +12V output (Ultra X3 1000W, PC Power & Cooling Turbo Cool 1000W, for example.)
http://www.jonnyguru.com/forums/showthread.php?t=3990
Reply to ct1615
Ah, I understand now. Thanks again for the info.
There are 2038 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 6 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
