Hello everyone, I recently built a gaming computer with the limited budget I had.
Once I got the machine up and running I immediately checked the BIOS and noticed the CPU temperature at 65C and climbing, it finally stopped at around 75C so I shut it down, reapplied the heat sink material, rebooted, and finished installing Windows. Once I made it to the desktop, I installed the utilities that came via the motherboard DVD.
Right now I have the Mode Setting at Max. Power Saving (Vcore is at 0.78v) and the CPU temp is around 45C at idle. While running the Prime95 stress test, the temp reaches up to 70C with the CPU fan running at 2500 RPM.
If I dare change the Mode Setting to Auto the CPU temp sits at 50C at idle. I tried running Prime95 and immediately stopped the test once I saw the temp reach 98C.
I guess my question is why are my temperatures so high?
And what can I do about it?
I've been using the motherboard utilities but I've also checked the BIOS and everything is on the default settings.
Although I am using the stock cooler I've been reading that temps like these are pretty much unheard of.
Here's my build:
CPU : Intel i5-760 @ 2.8 GHz
MB : ASUS P7P55D-E Pro
RAM : G.Skill DDR3 1600 2 x 2 GB
GPU : XFX Radeon HD 4870
PSU : Antec EarthWatts 650W
HD : Western Digital Caviar Black 1 TB 7200 RPM 3.0 SATA
Case : XCLIO Windtunnel
Thanks in advance for the help!!
Here's my build:
