K kg6i Distinguished Oct 28, 2010 3 0 18,510 Oct 28, 2010 #1 Hello, My Dell Inspiron 6000 won't boot, no video, HD spins, fan runs, plugged into AC power supply and battery is fully charged. Unit is 5 1/2 years old, so I suspect the CMOS backup battey may be TU. Need procedure to replace it.
hell_storm2004 Splendid Nov 23, 2009 3,645 2 23,165 Oct 28, 2010 #2 Do you hear any beeps? Upvote 0 Downvote
M mbarnes86 Splendid Sep 16, 2010 3,839 7 26,965 Oct 28, 2010 #3 Hi kg61 The Dell web site has good documentation for dismantling most of it's PC's & laptops and how to find and replace components. It is unlikely that a flat or dead cmos battery would prevent bootup On some older PC's the cmos battery is a re-chargable miniture nicad battery rather than a lithium button cell Do you have a spare screen to plugin to check if the laptop screen has failed ? or has diverted all output to the VGA port ? regards Mike Barnes Upvote 0 Downvote
K kg6i Distinguished Oct 28, 2010 3 0 18,510 Oct 28, 2010 #4 I thought of that too, will try the video on the outtput port, but by watching the HD activity LED, unit does not appear to be booting at all. Upvote 0 Downvote
K kg6i Distinguished Oct 28, 2010 3 0 18,510 Oct 28, 2010 #5 hell_storm2004 : Do you hear any beeps? Hell, no beeps. Upvote 0 Downvote
