CPU: core i5 2500k
MOBO: AsRock P67 Extreme4
RAM: G.Skill RipJaws 4GB (2x2GB) F3-12800CL9D-4GBRL
PSU: OCZ MODXSTREAM-PRO 500W
GPU: HIS RADEON 6850HD
SSD: AGILITY 3 120GB
OS: WIN7
Sorry to re-post, but I thought this issue was resolved. I'm having a problem running my system with a dual channel memory kit. If I put the memory in Slot 1 and 3 or 2 and 4 my system will not boot up. I cant even get into bios, the motherboard has a clr bios button on it that lights up. If I put the memory in slots 1 and 2 i can boot up and it recognizes both sticks of memory but as single channel. I have tried all the slots individually and they work.
I replaced the memory with a different type of G.Skill that was listed on the mobo website (F3-12800CL9D-4GBNQ). I'm still having the same problem. I have checked the timing and cas to make sure it matches up with the suggested settings for the memory and it does. I even upped the voltage from 1.50 to 1.575 and still nothing. I'm just wondering if I'm missing some setting that is causing it to not work dual channel. I know most likely the board needs to be replaced but I would like to make that my last option.
OS: WIN7
