- This is my system info from outervision power supply calc using (1 x GTX 260)
- If I add another GTX 260 it brings my total to 581 Watts, which is much lower compared to NeweggsPScalculcator(876 watts). Hopefully outervision's is more accurate.
This is my power supply..
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
620 watt (+3.3@24A,+5V@30A,+12V1@18A,+12V2@18A,+12V3@18A,- 12V@0.8A,+5VSB@3A)
*** I will not be doing any overclocking. EVERYTHING in the machine will remain stock.
Can I run this SLI and still have a safe and stable PC?
Thanks in advance for any help,
System Type: 1 physical CPU
Motherboard: High End - Desktop
CPU: Intel Core i7-930 2800 MHz Bloomfield
CPU Utilization (TDP): 90% TDP
RAM: 3 Sticks DDR3 SDRAM
Video Card: NVIDIA GeForce GTX 260 Core 216
Video Type: Single Card
High rpm SATA: 3 HDDs
DVD/CDRW Combo Drive: 1 Drive
Sound Blaster - All Models: Yes
USB: 6 Devices
Fans (Regular): 1 Fan 80mm; 7 Fans 120mm;
Keyboard and mouse: Yes
System Load: 90 %
Recommended Wattage: *486 Watts
