Hi all,
Just wondering if an xfx radeon 6850, will work on this board,
Here are the specs of the board:
Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
Supports Hyper-Transport 3.0 (HT 3.0) Technology
NVIDIA® GeForce 8200 Chipset
AM3 CPU Ready!
FSB 2600 MHz (5.2 GT/s)
Supports Dual Channel DDR2 1066/800/667/533 (4 x DIMM slots) non-ECC, un-buffered memory, Max. capacity up to 16GB
Integrated NVIDIA® GeForce8 Series DX10 VGA, Pixel Shader 4.0, Max. shared memory 512MB
Supports NVIDIA® Hybrid SLI™
1 x PCI Express 2.0 x16 slot (green @ x16 mode)
6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1, RAID 5, JBOD), NCQ, AHCI and Hot Plug functions
Dual VGA Output: Support DVI-D and D-Sub ports by independent display controllers
Supports HDCP function with DVI-D port, to enjoy better quality with High Definition HDCP Encryption contents
Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback with DVI-D port
NVIDIA® PureVideo™ HD Ready
Chipset embedded HDMI Audio which supports HDMI signal through DVI-D port by using DVI to HDMI adapter (not bundled)
1 x WiFi/E header, 10/100 Ethernet LAN
Supports Instant Boot
Supports ASRock OC Tuner, Intelligent Energy Saver
Windows® Vista™ Premium 2008 Logo Ready
Thanks
AM3 CPU Ready!
Thanks
