A friend of mine built me a comp a few years back which is currently running into some problems, 8800GTS burnt out , and I've decided to upgrade my rig. I put the money up but my friend was the tech savvy guy. I'm trying to select parts for a new build, but would like some feedback and some help.
I plan to pull the DVD drive, Hard drive, and 650W power supply out of the old comp.
For a new case, was gonna go with Antec 300.
(http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066)
For the motherboard, GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB. I would like to go 1156 as I'd assume it would be more upgradable in the future compared to the older 775.
(http://www.newegg.com/Product/Product.aspx?Item=N82E16813128425)
i5-750 2.66GH for the CPU. This comp will be for gaming and I've heard a faster dual core can perform better for gaming then a slower quad core.
(http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215)
Been a fan of GSkill, so I've been looking at Ripjaws Series 4GB DDR3 SDRAM DDR3 1600 (PC3 12800). Will go 4GB to start and double it up a bit down the road.
(http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277)
Finally, for the GPU, EVGA 512-P3-N871-AR GeForce 9800 GTX+ 512MB 256-bit.
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814130339&cm_re=9800_gtx-_-14-130-339-_-Product)
I'm a noob at picking parts for a comp, so any and all suggestions are welcome. I also intend to get Windows 7 along with the parts mentioned. I'd like to stay around an $800 budget. Also, I don't intend to start buying and building until late October/ early November.
Thanks in advance for all responses. The community on this site seems really friendly and helpful.
