I really could use some help with the install/setup of a replacement drive for my laptop.
Is the SSD compatible with my laptop?
What other issues may I be overlooking?
Could the security from fiberlink be effecting the install through the bios as well?
The Laptop is a HP Compaq 6715b, it was a work computer, I took out the existing hard drive because it had fiberlink security and was not useable. I bought an Intel 330 series SSD 180g to replace it and a system builder windows XP disk for the OS.
So the issue is that I get a Non-System disk or disk error message during the boot process.
What I have done:
I made sure that the boot sequence was correct (cd-rom-then-notebook drive), I also removed network boot up which was giving me a PXe-E6a code(this is now gone.)
I ran the Harddrive test and was a success for quick, comprehensive, and smart. However the test took around 5 hours to perform.
I removed and reseeded the hard drive to make sure it was properly connected.
I cannot find the SSD listed in the Bios, unless it reads "10000", but nothing shows up that reads "Intel HDD or 180G" so I am unsure if it is really registering.
I used another Windows 7 install disk that I have with no valid license to see if that would boot as well, and it did not.
So I need some more diagnostics to try. While I wait for someone to respond I am going to try the following:
Test the new drive on another laptop to see if it is a dead ssd.
Try to locate the latest bios for the laptop, and see if I can flash it from a USB thumb drive.
What I have done:
