Hello there i just bought a brand new Asrock Motherboard
ASRock M3N78D nForce 720D (Socket AM3) PCI-Express DDR3 16GB
With the AMD Phenom II X4 955 Black Edition Socket CPU
My power supply is a 480 Watt from my old computer temporary for 2 weeks untill i can upgrade it
I installed the computer and it worked great as i only just put the computer together i did not connect the fans LEDS case fans ect
But the wierd problem was when i connected everything together the power fan is very loud and scary so i dissconected all the case fans and leds and its normal again everything disconnected now but the bare essentials to get the computer running
i think its because my power supply is inadaquite for all the leads whats do you guys think
Also it was only on for a few seconds that cannot cause damage can it im using the computer now fine with zero problems
Thanks
Thanks
