Sign-in / Sign-up
First Build Components Advice i7 930
  • New Build
  • Systems
  • Product
Last response: in Systems
August 17, 2010 6:13:45 AM
This is my first ever attempt at a system build. I am a non-gamer, and most concerned about the compatibility of the components and what is adequate and what is overkill.
APPROXIMATE PURCHASE DATE: (within a month)
BUDGET RANGE: ($1000-$1500) After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: (Multitasking, MS Office Pro, surfing the internet, Photoshop, Video editing, streaming videos, watching movies)
PARTS NOT REQUIRED: (Keyboard, mouse, speakers,)
PREFERRED WEBSITE(S) FOR PARTS: (Newegg, and open to other suggestions)
COUNTRY OF ORIGIN: (USA)
PARTS PREFERENCES: (Intel Core i7930, mid or full tower case)
OVERCLOCKING: No
SLI OR CROSSFIRE: No / Maybe ?
MONITOR RESOLUTION: (not sure)
ADDITIONAL COMMENTS: (prefer an IPS monitor, one 24" or two smaller); (prefer mobo support for SATA 6, and USB 3.0.); (prefer modular type PSU). Confused on GPU requirements since I am a non-gamer.
PARTS ALREADY SELECTED:
Intel Core i7 930
http://www.microcenter.com/single_product_results.phtml...
G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8T-6GBRM
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
More about : build components advice 930
August 17, 2010 6:20:46 AM
Do you do Photo editing and Video often ? any other CPU intensive tasks...
m
l
August 17, 2010 6:26:35 AM
Yes, fairly often.
m
l
August 17, 2010 6:50:30 AM
Intel specific and NO AMD ? http://www.anandtech.com/show/3674/amds-sixcore-phenom-...
As for the build...
Mobo -
ASUS Ramapage III Gene - Very stable board
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
Or Gigabyte UD3R
RAM - Check this out...
http://www.tomshardware.com/reviews/6gb-ddr3-x58,2372-7...
CASE - Any specific reason for that case ? You wont be going SLI/ Crossfire and will not overclock so unlikely go watercooling, then that case is not worth it IMO...
If you want a similar looking case, then the HAF 922 would be a good option...
Monitor -
http://accessories.us.dell.com/sna/products/Displays/pr...
Graphics card -
or
If you will be using AfterEffects and PremierePro majorly, then get the Nvidia cards as those take advantage of CUDA...
m
l
September 7, 2010 5:48:10 PM
gkay09,
Thanks for the insight, and apologies for the long delay in responding. I've been recovering from a recent surgery that has slowed me down the last few weeks. Anyway...
I think I'll go with the GIGABYTE GA-X58A-UD3R rec. That was my major concern. And I think you're right about going with the HAF 922 case.
However, I am thinking I should go a little higher on the PSU, maybe 750W in anticipation of future upgrades... additional HDDs/ODDs, etc.
I neglected to mention in my original post that I will be going with one WD Caviar Black (1-Tb), and hopefully one SSD if I can handle it. Any recs on the SSD? They still seem to be ridiculously expensive! What capacity SSD would be adequate for handling the OS plus say MS Office and Photoshop apps?
Thanks again...
As for the build...
Mobo -
Or Gigabyte UD3R
If you want a similar looking case, then the would be a good option...
Monitor -
Graphics card -
or
m
l
