Heres my situation.
Had an Athlon 2400, Nvidia GTS250, M2N-MX-SE motherboard, 2g DDR2,
It foze up about a week ago, the HDD light would be lit whenever i tried to power up, but would not boot.
I did some testing, removing all the parts, and it was the same always, even with just the PSU, mobo and CPU, so I figured it was the Mobo, needed an upgrade anyway, so I bought a P5G41C-M LX and a celeron E3300.
When I popped everything back into the mobo and started her up to reinstall Windows XP, It was normal, until a couple of minutes into the install process it shut down. The graphics card was boiling. which was strange because It has run fine before in the old motherboard. My PSU is a generic 480w, which has worked fine for the past... 4 or so years. Whenever i turn it on now, the CPU fan spins for a second, before stopping.
Another thing is that when I took out the 250GTS and put in an old Nvidia 7900 card, it works fine. (Okay while I was typing this, It shut down and started spinning wildly) I took it out, and the thing boots up fine. I'm even typing on it ATM.
Could it be the PSU not powering it, with the new processor now. Or the Graphics card fried? Also Would I have to do something with the BIOS? (I think this motherboard has onboard graphics)
I dont mind replacing it, just frustrating not knowing.
Thanks a heap advance.
Happy to post specific steps but its late and I've spent the entire day trying to figure this out.
