Is this Enough Power!??
Last response: in Components
November 1, 2010 5:39:09 PM
Hey guys, Windows 7 64- Intel core i5 750 @4ghz -4GB 1600mhz ram - dvd drive - 4 usb's using - 2 x evga 465 gtx 1gb overvolted and overclocked 42% increase - and thats pretty much it, I had a corsair 950 watt and was giving me nonstop bsod's, changed psu and havent had issue since, also it died about a week into having it, so im lookin at new power supplys on newegg and I found - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
http://www.coolermaster-usa.com/product.php?product_id=...
my only question, Why is there only a 2 year warranty? is there any other good power supplys in the 900watt-1000 watt range that I can get with under $200 with a decent warranty??
Thanks very much! -Jim
More about : power
November 1, 2010 5:41:08 PM
forget the 2 year warranty thing, newegg doesnt have the correct info on there details on that psu, its a 5 year :)
m
l
a c 709 ) Power supply
November 1, 2010 7:14:15 PM
Wasn't the Corsair under warranty? It should have run the system fine, RMA it for a replacement.
m
l
