Hello! I'm currently looking to have a system built in the beginning of September and right now I'm just looking at parts. I am not going to build this myself, but an experienced friend is going to help me assemble this computer.
So far what I've found are and I'd like some recommendations for the ones I have left blank!
CPU: Intel Core i7-930 (I am definitely sticking to this CPU since MicroCenter has it for $199!)
Mobo: Gigabyte GA-X58A-UD3R (Is there a better Motherboard for around the same price or cheaper?)
GPU: Gigabyte GeForce GTX 460 (I will most likely upgrade by adding another GTX 460 down the line for SLI)
Memory: G-Skill 6GB DDR3-1333 (3x 2GB)
Case: (Not looking for something too flashy, maybe the CM 690 II Advanced?)
Fans: (Not sure if I will need to buy these, depending on the case)
PSU: (I was advised to get a 750w power supply, but I'm not sure what brand to get)
Other: (What am I missing?)
In the end, I am looking to spend between 800-1000 dollars by looking for deals and Newegg combo discounts.
Links are appreciated
Thanks!
Thanks!
