Ok so ive decided that there is no way in hell im going to pay as much as alienware and others are asking for a gaming computer and id like to go ahead and build my own. Having said that...Ive only just started to figure out how exactly to build one. I think ive done enough research and have at least what i think are parts that all are compatible with one another and are in my price range. Heres the build i put together by roaming through tiger direct
MOTHERBOARD:
MSI 785GM-E51 Motherboard
CPU:
AMD Phenom II X4 965 Black Edition Processor w/ Fan
RAM:
OCZ OCZ3G1333LV8GK Gold 8GB PC10666 DDR3 Dual Channel Memory Upgrade - 1333MHz, Non-ECC, Unbuffered, 2x4096MB
HARD DRIVE:
Western Digital WD5000AAKS Caviar Blue Hard Drive - 500GB, 7200rpm, 16MB, SATA-300, OEM
GRAPHICS CARD:
XFX HD585XZAFC Radeon HD 5850 Video Card - 1GB GDDR5, PCI-Express 2.0, CrossFireX Ready, Dual DVI, Display Port, HDMI
CASE:
Thermaltake Element G Mid Tower Case - Colorshift Fans, Adjustable Fan Speed, 7 x 3.5" Drive Bays, 2 x 2.5" Drive Bay
POWER SUPPLY:
Ultra LSP750 750-Watt Power Supply - ATX, SATA-Ready, SLI-Ready, 135mm Fan
DVD BURNER:
ASUS DRW-24B1ST/BLS/B/AS 24X DVDRW Drive - SATA, Black, OEM
.....ok so im wondering if there are any incompatibilities or changes needed to be made...i also feel anything to give better performance from the graphics that wouldnt go over $150-200 more would be ok... Im going to be using this for gaming and programs like maya. Btw this build came to right around $1000 yet id be willing to go to 1200.
any suggestions or help would be greatly appreciated Thanks
MOTHERBOARD:
CPU:
RAM:
HARD DRIVE:
GRAPHICS CARD:
CASE:
POWER SUPPLY:
DVD BURNER:
