Closed Solved
I think i need a new power supply
Do i need a new power supply? This chart shows 10 minutes of gaming in Starcraft 2 with setttings on Ultra and 4x AA in catalyst. http://s993.photobucket.com/albums/af51/tdra60/?action=view&current=Capture.png
Notice how my CPU is not maxing out at 100%...It is odd since SC2 is CPU intense. And on the left my GPU average is below 100% as well. I currently have two ATI Radeon 6870's in crossfire w/ an AMD 955 black edition.
Will any other information help decide whether I need a new power supply?
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817171037&Tpk=cooler%20master%20silent%20pro%20m700
G-CARD: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161349
5 answers Last reply Best Answer
More about power supply
  1. SCII is very CPU intensive, but only on two cores, which is why you only ever hit about 60% usage, 50% comes from SCII the rest come from windows tasks. Your GPUs look like they were reasonably close to 100% load which is good considering that SCII is usually CPU bottlenecked.
    Its unlikely that your power supply is limiting your performance, it doesnt usually cause things to throttle it generally just shuts itself down.
  2. Best answer
    SC2 made be CPU intense but that's only for two cores, its not 3+ optimized. A phenom II x2 runs neck and neck with a x4.
    http://www.techspot.com/review/305-starcraft2-performance/page13.html
  3. Best answer selected by dirtypillows.
  4. I think you need a new anti virus.
    Norton sucks....
    MSE is way better and free *unless you have a pirated version of windows then lulz thats your fault*
    http://www.microsoft.com/security_essentials/
  5. This topic has been closed by Mousemonkey
Power Supplies CPUs Starcraft 2 Components Product
