E easy772 Distinguished Jun 10, 2010 72 0 18,630 Jul 15, 2010 #1 Hey, I have a Vostro 220s (Slim Case) and am wondering what is the best graphics card that would fit in the case for ~100. The main game I will be playing would be Starcraft 2. Thanks.
Solution rolli59 Jul 15, 2010 HD5570 http://www.newegg.com/Product/Product.aspx?Item=N82E16814161345 it is very power efficient and will run on a 250 watt PSU
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Jul 15, 2010 #2 Low profile HD5570 depending on the size of the PSU. Upvote 0 Downvote
E easy772 Distinguished Jun 10, 2010 72 0 18,630 Jul 15, 2010 #3 It has a 250w or 300w power supply, I don't remember.. But what's the best low profile card I can support assuming it's a 250w? Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Jul 15, 2010 Solution #4 HD5570 http://www.newegg.com/Product/Product.aspx?Item=N82E16814161345 it is very power efficient and will run on a 250 watt PSU Upvote 0 Downvote Solution
E easy772 Distinguished Jun 10, 2010 72 0 18,630 Jul 15, 2010 #5 Best answer selected by easy772. Upvote 0 Downvote
E easy772 Distinguished Jun 10, 2010 72 0 18,630 Jul 15, 2010 #6 Thanks a lot, will probably look for the best price for it now Upvote 0 Downvote
