Hi all,
I have built a system for myself which has this problem that it can't turn on sometimes. I would press the power button and the fans will rev up for a second just to turn off after that. The system will remain off until I press the power button again to turn it on just to see the same thing happen. It will happen for a while until the system just turns on.
It has also happened a few months ago and when I opened the system I saw that my heatsink had a few screws which seem to touch the casing. Since then I used the provided rubber under that and it seemed for work fine until now when it just decided to do this again!
I would really appreciate if you guys could guide me on some general debug steps.
Thanks in advance!
Thanks in advance!
