Sign-in / Sign-up
Solved
Memory or graphics problem?
  • Memory
  • Graphics
Last response: in Memory
June 29, 2011 5:32:02 AM
I had 4 (2x2) gigs of memory running on my 64bit W7 system until I started getting system freezes and ran memtest to find out that one of my sticks was bad. Now I am running off of a single 2GB stick. The problem temporarily disappeared but has reappeared lately, usually when I'm playing games or doing anything that causes system load. I ran memtest and get no errors.
My Last BSOD:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 1000007e
BCP1: FFFFFFFFC0000005
BCP2: FFFFF8800F4B42A1
BCP3: FFFFF88006D11108
BCP4: FFFFF88006D10960
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Can anyone help confirm / give any other explanations as to what might be wrong?
-Thankyou
More about : memory graphics problem
a b } Memory
June 29, 2011 4:22:23 PM
What is the make and model of the memory?
So the system ran fine for a long time, then one day it started giving you problems? Or it's been a problem since day 1?
Is the stick your having trouble with running in the same dimm slot as the bad stick you took out?
m
l
June 30, 2011 12:38:51 AM
These are the make / model:
I've had my memory for about a year and my computer for 2+ so its just randomly been giving me problems starting about 2 months ago.
I switched the DIMM slot of the current memory and got no real change leading me to believe the slots on the MB are okay.
m
l
Best solution
a b } Memory
June 30, 2011 2:06:32 PM
I would rma both sticks, but first I would check bios to make sure something hasn't changed.
Make sure the dimm voltage is set to 2.1v.
June 30, 2011 5:02:42 PM
Best answer selected by dfraaz.
m
l
