I built my computer from scratch, but never had this problem before.
My computer consists of
CPU: AMD Athlon 64 X2 4200+ Windsor
Motherboard : Gigabyte GA-MA69GM-S2H
http://gigabyte.com/products/product-page.aspx?pid=2579&dl=1#ov
4 gig DDR2 Quality Ram
4 Hard drives
500 W Power Supply
It runs like a charm, its on 24/7
Then i decided to by a new graphic card for it, so i got the ATI Radeon X1900 XT
which was runnin fine for a while, til it started to crash every time i started a game..
i figured that it was runnin to hot becouse of the funny looking built in fan..
So i bought a new graphic card, this time the Sapphire ATI Radeon HD 4670
That didnt help the crashes, it only made it worse.. so i figured that i probably
had to little power, since i have 4 harddrives (20 gig, 80 gig, 160 gig, 1TB)
So i disconnected all but the 20 gig hard drive.. and tried to reinstall windows
from scratch with the new graphic card installed..
Problem is, I could not get trough a whole windows install without the computer crashing..
it is like someone pulled the power cord, everything goes out at once, and the screen goes black..
no pixles or any disturbance in the picture at all..
I took the card out and the crashes stopped, so i could finish installing windows..
Since both graphics card acted the same, I figured that the only thing that could be wrong, would be the motherboard or the power supply, even tho 500W seems to be plenty.. I'm thinking of flashing the motherboard bios, but thought i would ask in here first.
What causes the crashes?
Tyvm for the input!
4 Hard drives
500 W Power Supply
Tyvm for the input!
