xmanli said:
Hi again,
I can't decide with CPU to choose. Is there any performance review/benchmark to show differences between Intel I5-760 & AMD Phenom II X6 1055T for the specific purpose of my PC jobs???
I guess my work come in the category of Multi-tasking, I am not sure though !
Would it better for me to use 64-bit OS ? I guess it is due to more RAM will be usable ? If I only use 32-Bit OS, will it be better to use SSD for OS and page/swap file so that it can cover the performance deficiency due to less RAM usable ?
Also, please advice which Graphic card will be enough powerful for my PC work load, I don't want to have a GPU bottleneck.
Thx again
well, since you specifically mentioned photoshop, but not gaming, yo do want a GPU, but it doesn't necessarily need to be bleeding edge model. you also might want to consider a dual monitor solution for enough workspace for everything.
I'll start with the X6 processor. As much multitasking as you are doing, I think you'll see great benefit from 6 processors. All prices are from Newegg, pre-rebates, and no combos as you're buying in hong kong:
APEVIA X-DREAMER3-AL Silver Metal ATX Mid Tower Computer Case
$49.99
A plain looking case (white w/ blue LED fans), but comes with 3 120mm fans. 1 front, 1 back, 1 side, and should be great for cooling.
HITACHI Deskstar HD31000 IDK/7K (0S00163) 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
$15.00 Mail-in Rebate Card
$64.99
I chose the hitachi as a good brand that was on sale right now, with that rebate. While the Samsung f3 1TB drive is the fastest 1TB drive right now, its hard to find in the hong kong shops. Any 1tb drive with a 32MB Cache from Hitachi, Samsung, Western Digital, or Seagate will be solid and reliable.
ASUS M4A88TD-M AM3 AMD 880G SATA 6Gb/s AMD Motherboard
$89.99
You can find biostar for a little cheaper, but Asus is a top brand and Biostar isn't. This board has SATA 3, USB 3, and 4 RAM slots.
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
$144.99
Prices may vary in hong kong for a 5770, but it should be $140-160US
SeaSonic SS-400ET Bronze 400W ATX12V V2.2/EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power ... - OEM
$48.99
You only need a 400W supply for this build, this is a solidly reliable power supply 80+ bronze certified from the very reliable seasonic company. Other reliable companies include thermaltake, antec, cooler master, OCZ, Ultra, ad Silverstone. the lease expensive 400W bronze from any of them will serve you well.
2xA-DATA 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model AD3U1333B2G9-DRH
$163.98
($81.99 each)
4x2 GB chips is MUCH, MUCH cheaper than 2x4GB chips. You'll want the 8GB with everything you are doing at once
AMD Phenom II X6 1055T Thuban 2.8GHz Socket AM3 125W Six-Core Desktop Processor HDT55TFBGRBOX
$199.99
Subtotal: $762.92, $712.92 after rebates.
Other things to consider:
a 1920x1080 monitor from Acer is $169. You can run this with your existing monitor.
Windows 7 home premium 64 bit: $99
a 64 GB SSD for a boot/applications drive: $139-179, optional but will see the best performance increase
Wireless N PCIe card: $20 for a reliable brand
