Hi!
I have the following config:-
AMD X4 955BE (STOCK)-undervolted to 1.175 V
GIGABYTE GA-785GMT-USB3 (m-atx)
Gskill Ripjaws 4Gb(2x2) 1600Mhz
ATi 5850 -MSI Twin Frozr2
Corsair VX 550
2x1TB+2x500Gb
Coolermaster Hyper TX-3 HSF(will be replacing it with Scythe Katana-3 soon)
Gigabyte X-142-LUXO--PC case
Sony DRU 870A(Dvd writer)
Case Fans - Coolermaster Blademaster 120mmx2+Thermalright 120mmx1
These are snaps of my system :-
As you can see, the cable management is not very good but its the best I could do with the existing case I have.
I am obsessed with silent operation and neat cable management. I don't intend on overclocking my system. I plan to get myself a new case. I've zeroed in on the Antec P183.Will the corsair vx550 fit properly in an Antec p183? Will the dimensions of the PSU I have and the length of the cables of the PSU, ensure a proper fit in the P183?
If not what are the other possible cases I should be looking at? I have a budget of upto 100-120 US $
I liked the Coolermaster Sileo 500 but then it has no cable management and the PSU sits on the top.
Kindly suggest me a case which DOES NOT HAVE the following things:-
[1] Mesh design
[2] Transparent side panel
[3] Lousy LED lights and LED fans (absolutely a strict NO-NO - I hate these!)
The case I need should have the following things:-
[1] Bottom mounted PSU (top mounted psu will do if nothing that suits my needs are available)
[2] Atleast 2 120mm fan mounting holes
[3] Capable of housing CM Hyper 212+ or a large HSF (incase I decide to overclock)
[4] Capable of housing ATI 5850
[5] Offers good cable management
[6] Preferably powder coated interior
[7] Dust filter
[8] Well constructed and silent
Corsair VX 550
2x1TB+2x500Gb
[1] Mesh design
[7] Dust filter
