G
Guest
Guest
My 1st build and i'm in the BIOS. My Hard drive that i'm going to instal Windows on is smaller in size than a standard SATA drive. My Case is a Cool Master and the only place that I can see where this small HD will fit is on the outside (on the top) of the machine. It's sorta just slides in. Does this sound correct? The only other slots for HD's are for the standard size ones... The case says this is a new feature for people on the go or something. Sorry if this sounds dumb. Any advice?
