Solved
Need advice on new custom build
APPROXIMATE PURCHASE DATE: September-ish
BUDGET RANGE: about 600-650 before taxes
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: School, gaming, surfing, movies ect.
PARTS NOT REQUIRED: don't really need dvd burner or speakers. OS is a plus but can get my hands on one if anything.
PREFERRED WEBSITE(S) FOR PARTS: anywhere really
COUNTRY OF ORIGIN: Canada
PARTS PREFERENCES: Most cost efficient
OVERCLOCKING: Maybe?
SLI OR CROSSFIRE: huh?
MONITOR RESOLUTION: doesn't really matter
9 answers Last reply Best Answer
More about need advice custom build
  1. You need a monitor?
  2. yeah i need a monitor too
  3. Best answer
  4. Thanks mosox that looks like a great build for the price. One question though; the vid card is the one integrated into the motherboard right? Can you run most recent games at a decent quality/ res with that vid card?
  5. Oops, forgot this, sorry:
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102855&cm_re=hd_4670-_-14-102-855-_-Product
    You have a great monitor there and no, you can't run the latest games on a higher quality, only on medium quality (lower resolution) in that budget.
    The alternative is to wait and use the onboard video until you get the money for a better video card like a HD 5770. Or get only 2G of RAM (you can add later) and a HD 5770 but that's over your budget:
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121363
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145246
    $695.93
    Anyway I think you shouldn't buy a cheaper smaller monitor.
  6. I wouldnt be able to run games on higher qualities with the the HD 5770? Honestly my goal is really just to play them on medium settings low if necessary but i dont want it to be outdated by like next year... will this build allow me to still play games in a year or 2?
  7. I was talking about the HD 4670 . With the 5770 you can play everything on high or medium for a couple of years, it's a good card.
  8. Alright thanks for the info mosox
  9. Best answer selected by Raffi_14.
New Build Systems
