Solved
Building a 460 SLI system
APPROXIMATE PURCHASE DATE: Mid to Late Sept.
BUDGET RANGE: ~$1500-$1700.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Movies, Music.
PARTS NOT REQUIRED: Keyboard, Mouse, Case(already purchased), Monitor.
PREFERRED WEBSITE(S) FOR PARTS: Newegg, TigerDirect
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: Intel I5 or I7; Corsair power, GTX 460 SLI
OVERCLOCKING: yes
SLI OR CROSSFIRE: SLI
MONITOR RESOLUTION: 1920x1080
Intel Core i5-760 + ASUS P7P55D-E
$345
Crucial 4GB (2 x 2GB) CT2KIT25664BA1339 DDR3 1333 x2=8gb
$180
ASUS ENGTX460 GTX 460 1GB x2 in SLI
$490
Scythe SCMG-2100 Sleeve CPU Cooler
$40
Arctic Silver 5 Thermal Compound - OEM
$10
OCZ Agility Series OCZSSD2-1AGT120G
$262
HITACHI Deskstar 7K2000 2TB 7200 RPM
$110
LITE-ON Black 4X BD-ROM
$65
LITE-ON Black DVD+RW
$20
CORSAIR HX Series CMPSU-750HX 750W
$150
Total: $1672
Looking to build a system for a friend. So this is loosely at what I am looking at getting for him.
Let me know what you think, and thanks!
UPDATE: Close to the final build I think...
25 answers Last reply Best Answer
More about building system
  1. Best answer
    ^ I would recommend a different mobo, if you are planning to go SLI as well as want to use the USB3.0/ SATA 6GB/s feature of the mobo...Check this review...
    http://www.tomshardware.com/reviews/usb-3.0-performance,2490.html
    So that ASUS P7P55D-E Pro would be my choice...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
    RAM - IMO go with a tighter timings like these instead...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226123
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226120
    PSU - For GTX 460, you wont need 850W...Even the Corsair 650HX would suffice...but if you want, get the Corsair 750HX...
    SSD- Why not the newer ones ??
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820227542
    Thermal grease - Get a different one instead...
    MX-2/ TX -2 or TX-4...these unlike AS5, dont need curring time, and most importantly are not electrically conductive, hence even by mistake if you drop it on the other components, there is no risk of shorting...
    And which case does your friend have?
  2. Took a look at your suggestions and updated above.
    Thanks a bunch for the mobo review. Been having a little annoyance with my old asus board, so been looking a little closer at gigabite's products, but I see what you're talking about.
    As for RAM you like the tighter timings over going with 2200?
    Honestly, I know 8gb is more then really needed at this point, and we might just go with 4gb to start with and save some money, but am I also overkilling with this high of quality ram as opposed to going with Crucial? Price is a consideration and I'd love to get things more around a $1600 for where we are with the CPU and SLI setup.
    Took a closer look at psu and agree. Just hammered out the specs on corsair's site at first.
    Might go for the original SSD to save $ also, but put in your suggestion as of now.
    As for the thermal, I see that AS5 has a "breaking in period," but don't see a curing time like Coollaboratory Liquid Pro. Regardless, always good to take a closer look at things. Will research a little more. Wish MX-4 was already out. Stuff looks great for $5.
    As for the case, it's full size, but will have to get back to you on the actual brand. Fairly certain we wouldn't have a problem fitting in the cooler, or the SLI. Trying to talk him into an Antec. Have a 900 myself and love it.
    Thanks again.
  3. As for the RAM, take a look at this article, though old, but is based on the same speed vs timings...
    http://www.tomshardware.com/reviews/tight-timings-high-clock-frequencies,1236-10.html
    That Crucial RAM is IMO the best value for money if you are a overclocker...And that Crucial RAM is also a high quality RAM...
  4. For PSU you might want to consider Antec TruePower New TP-750 80 PLUS BRONZE as it is currently cheaper after the mail-in rebate, and it might give you some room for future upgrades.
    Review of the PSU at jonnyGURU.
  5. Yup, seen nothing but good things about that ram. Updated using Crucial. Think he'll be happy with that, rather then paying a $100+ premium.
  6. Looks like that Antec kinda is defeating the purpose of being modular...
    I know he's looking for good cable management and airflow. Looks like a great PSU otherwise, as well as a good deal, though I'd probably go for this instead tbh. Call me a Corsair fanboi, lol.
    One more thing to pass by him. We're getting at a reasonable price so we have some flexibility.
  7. Corsair is great too, though the one you listed is not modular, the TX line is all hard wired, you have to get the HX line for modular cables.
  8. Take a k at the AZZA Solano 1000 It's a nice case with 5 fans 2x230mm 3x140mm heres a link.
    http://www.pureoverclock.com/review.php?id=760&page=2
  9. I would not recommend getting sli 460s. What are you going to do when it comes time to upgrade? You are better off getting a GTX 480 now and another later. Never start a build with SLI.
  10. Well if you can afford 2xgrforce gtx 460 SC running SLi I'd go for it. As long as your PSU has enough juice to run 2 480s down the road thats what you could UG to. Right now a SC 480 is about a lil over $600 a piece you can get 2 460's for about $400 to $450 for both.
  11. I picked up my GTX 480s for $408 each off newegg.com the other day. It is simply not a good idea to start with an SLI system of lesser cards. Where do you go from there? Nowhere. Get one GTX 480 and then another down the road.....
    Hell check this deal out you could have had the other day GTX 470s were going on newegg for $223
    http://dealnews.com/Ge-Force-GTX-470-1.28-GB-PCIe-Video-Card-for-223-after-rebate-free-shipping/383424.html
    You should wait for another deal like that or get one GTX 480
  12. Good point about SLI, but here's where I'm thinking from on starting with it with 460s. The scaling is better the a 480. They'll be giving the best bang for his buck at this point. Plus, not a big fan of the higher end fermi cards at this point, especially from a cooling perspective.
    I know they've put out some cards with some nice coolers beyond the reference version, but would be paying a premium for it, and doubtful that they'll be seen at the price you picked up your 480s for before build time. That's actually why I'm going with the Gigabyte 460s, for the dual fans.
    But again, it a good point that's made. I'll bring it up to him.
    What do you think of the idea of going to a i7-930 with a 1366 platform, giving the option of going with tri-SLI on the 460s in the future? It'd be tight, but we might be able to fit that in the budget.
  13. ^ IMO GTX 460 SLI is the best-bang-for-buck...
    As for the GTX 480, in few months time, Nvidia and ATI both will be launching newer cards, so GTX 480 would very well be replaced soon enough...
  14. Do you live near a microcenter? They sell the i7 930 for $199.00 If not here is an i7 build within budget with a GTX 480 and 1000w psu for future SLI
    Here is what I would build if I were you...
    CPU: i7 930 $298.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
    MOBO: X58A-UD3R $209.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
    CASE: Haf 922 $90
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
    RAM: CAS6 Mushkin Redline $189.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226121
    HDD: Seagate 1tb 7200.12 $ 75
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433&Tpk=seagate%201tb%207200.12
    DVDRW: $22
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106334
    Blu-Ray $65
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106326
    PSU: Mushkin 1000w $99 after rebate
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817812009
    Windows 7 $99.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
    CPU cooler Hyper 212 $50
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=cpu_cooler-_-35-103-065-_-Product
    GPU: GTX 480 $450
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125319
    GRAND TOTAL IS $1691.89 Without the $50 MIR.
    Leaves some room for future upgrades...
    If you switch the gtx 480 for 2x 460s then it's a bit more at $1,701.00
    Here is the public wish list with the 460s.
    http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=18354007
  15. Nope, no Microcenter in North Carolina.
    Intel Core i7-930 + GIGABYTE GA-X58A-UD3R
    $484
    Crucial 6GB (3 x 2GB) DDR3 1333
    $141
    GIGABYTE GeForce GTX 460 1GB x2
    $460
    This build would be for looking at adding a third 460. If we decide on a 480 we could stick with the above build, but again, it would have to have non-reference cooling.
    $40
    $10
    OCZ Agility 2 OCZSSD2-2AGTE60G
    $170
    $110
    BTW will never buy a Seagate drive again. They're crap IMHO.
    $52 (-$13 bundled with a GTX 460)
    $20
    SILVERSTONE RAVEN RV02-BW
    $160
    We'd need 8 slots in the back to throw a third card in with this Mobo. I'm fairly positive the one he has only sports 7. The Haf 922 only has 7 also btw...
    CORSAIR TX950
    $140
    For a PSU, I'll stick to a name I can trust, rather then one with 3 reviews on newegg, 2 of which were DOA tyvm. We'd have to mod the case with it being wired for max airflow, but going past $200 for a modular PSU is a little too much of a premium to pay.
    Grand total: $1787
    Have to do a bit more research on this, especially the Mobo's Tri-SLI performance. Might be worth the $280 for future-proofing, though the OP build still looks really nice, and will last him for a long while regardless.
    If we did go with a 480 the ZOTAC AMP! looks to be the only viable option for his cooling desires. Add that plus the tx950 to the 1156 build would bring our total to around $1587. Hmmm... dilemma.
  16. ^ I think you have missed an important point - GTX 460s wont do Tri-SLI as they have only 1 SLI connector...
    But if you are looking for a better card - more powerful than the GTX 460, then maybe the GTX 470 - especially this Gigabyte card -
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125338
    Review -
    http://www.tomshardware.com/reviews/gv-n470SO-13I-super-overclock-geforce-gtx-470,2713.html
    But cant match the value of 2x GTX 460s though...
  17. >.< doh...... there goes that idea. Thanks for the save :D
  18. Take a look at my build! Only thing I didnt buy was an SSD
    CD: Sony 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive
    CD2: Sony 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive
    CAS: AZZA Solano 1000 Full-Tower Advance Cooling Case w/ Dual 230mm Fan + Extra 3 Fans
    CASUPGRADE: 12in Cold Cathode Neon Light (Blue)
    CPU: AMD Phenom™II X6 1055T Six-Core CPU w/ HyperTransport Technology
    FAN: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA)
    FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer
    HDD: 1TB SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD
    MEMORY: 4GB (2GBx2) DDR3/1600MHz Dual Channel Memory Module (Corsair)
    MOTHERBOARD: Asus M4N98TD EVO AM3 NVIDIA nForce 980a SLI Chipset DDR3 ATX w/ 7.1 HD Audio, GbLAN, USB2.0, IEEE1394, SATA-II, RAID, 2 Gen2 PCIe, 2 PCIe X1 & 2 PCI
    NETWORK: Onboard Gigabit LAN Network
    POWERSUPPLY: 850 Watts - Corsair Gaming Power Supply - Quad SLI Ready
    SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
    TEMP: Aerocool Touch 2000 Dual Bay Touch Screen Fan Control
    VIDEO: NVIDIA GeForce GTX 460 1GB 16X PCIe Video Card (EVGA Superclocked)
    VIDEO2: NVIDIA GeForce GTX 460 1GB 16X PCIe Video Card (EVGA Superclocked)
  19. @ MR.ROGUE^ That motherboard is not USB 3.0 or SATA 3 6gb/s...ie its an older board and will not work with SATA III.....the hard drive that is selected.
  20. I would lose the ssd. only thing you're going to be able to install on it is 1-2 games and windows. big deal, windows will load fast and those 2 games. the rest of your games are going to be installed on the harddrive and that ssd wont help you any ingame. ssd's are too high still atm to be worth getting. loading windows and some games is great but most games you play online you still have to wait for games to start(cod, bfbc etc) so loading faster doesn't even help.
  21. Ok, finally nailed my friend down and got some input from him.
    We're going to use a APEVIA X-CRUISER-BK Black Steel ATX Mid Tower
    He's had it for a while, but it's still practically new, and we'll probably do some modding to get some more fans on it to help with some cooling issues that might crop up.
    He's happy with the 460 SLI setup, as they should have fairly good longevity. Two things I'll update up top is we'll be going to a 750w Corsair PSU, just in case, and bump up to a 120g SDD. I'll get all that edited by the end of the night.
    Again, thanks for all the suggestions!
  22. ^ Any particular reason for that case ?
    How about this combo ? A high quality case with a very good PSU...
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.466882
  23. It's bought and paid for. He's had it for a few years tucked away actually and he likes it. We'll make sure we have some more fans modded in it to make sure cooling isn't an issue.
  24. With the new 460 review, and some more research, ASUS beats Gigabyte again for what we want: performance and cooling.
    Got the updated build in the OP.
  25. Best answer selected by Drace.
New Build Systems Product
