I guess I should start by introducing myself. I'm not a computer noob, I just don't have as much experience as most of you. And I've been educating myself by reading on here. I am also in progress of building a new computer (for gaming and basic use). The purpose of my post isn't that I need help in picking out components, I have that all planned out. I have so far a ThermalTake V5 case and a Corsair HX850 (I buy funds permitting and as things go on sale).
My current pc until my new one is finsihed is an old hp with:
core 2 e6300 1.86ghz
HP OEM mobo
2gb 333mhz ddr2 ram
intel igp
OEM hp case &psu
2 Samsung 80gb hdd's
Windows 7 32bit
I understand how outdated this setup is, but I will be running it, well it and my laptop (which is much much faster lol) until my new pc is finished.
Anyways I was just planning on leaving the hp as is until my new pc is finished. But the psu fan has been running at max speed lately and it has become very loud. I have opened the psu and cleaned it completely with no avail.
So I was planning on putting the everything from my hp into my V5 with the hx850 and swap in components as I get them.
Now to the problem: Everything fits perfectly except for the heatsink which appears to hp OEM not intel. I have done a lot of research on this but haven't found anything.
My hp has a motherboard tray the V5 does not; and on the motherboard tray there are holes for where the heatsink bolts into instead of the things you turn on the Intel ones I've been seeing. There are no holes in the case anywhere near the cpu.
So here's possible solutions I came up with:
1) Put hx850 in hp case: I don't want to run the hx850 without a dust filter. The v5 has a filter for the psu. I don't want to open the psu to clean it, as that voids the warranty.
2) Use bolts/brackets underneath to hold heatsink: A bit too rigged up for me and I'd probably break or short something.
3) Buy new regular heatsink for 775: seems like a waste of money that could be put toward new pc, especially
since the hp one works very well (has heatpipe design)
4) Buy new psu for hp (around 400w or so) and then leave hp alone: again more money that could be put toward new pc even though I'll eventually buy a new one I want to finish my build first
5) Just deal with the noise and keep hp as is: it will just be a while before pc is completely done (I'm waiting for Sandy Bridge). So is possible but not ideal
I prefer options 3-5, but if you have a thought or alternative let me know.
I apologize that this was rather lengthy write up but I wanted to give as much detail as possible it seems like a common request to be detailed.
Thank you for you time.
