Asuse p5kpl-am se motherboard's fornt sound jack
I have asuse p5kpl-am se Motherboard. my Front jack doesn't working studiedly. i have re plugged all the cables again. it doesn't working i don't have any idea why is that, Help me plz
1 answer Last reply
More about asuse p5kpl motherboard fornt sound jack
  1. Welcome to Tom's Forums! :)
    If you mean the Front Panel connection from the MOBO to the Case then it could easily be the case's jack's are broke or slim chance corroded. To attempt a fix, corroded, shutdown the PC and with Isopropyl alcohol drip the headphone jacks in the alcohol insert in the case jacks and twist, wipe-off and repeat a few times.
    Otherwise you can get a different jack, USB Audio adapter or use the MOBO's rear I/O audio out.
    Options:
    Audio + Reader - http://www.newegg.com/Product/Product.aspx?Item=N82E16820132020
    USB Audio - http://www.newegg.com/Product/Product.aspx?Item=N82E16812186035
Asus Motherboards Cable Product
