my pc running in DDRII,so can i use graphic card that built in GDDR3 spec??
PAKLI Distinguished Dec 8, 2009 9 0 18,510 Jul 16, 2010 #1 my pc running in DDRII,so can i use graphic card that built in GDDR3 spec??
Maziar Champion Jul 20, 2007 21,707 1 52,960 Jul 16, 2010 #2 As long as you have a motherboard with PCI-E slot, you can use a GDDR3 PCI-E card on it
g00fysmiley Distinguished Apr 30, 2010 2,175 0 19,860 Jul 16, 2010 #3 yes, the graphics card ddr spec doesn't affect the systems ram you can even use a card with ddr5 without problems
