APPROXIMATE PURCHASE DATE: TBA xD
BUDGET RANGE: $1000 Before / After Rebates(better with rebates)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, surfing the internet, watching movies
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS
*RAM,HDD and Optical Drive maybe not necessary cuz i have a Pc right now and i can use those.
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, tigerdirect.com. ncix.com <-i dont know this website but if they have rebates good xD
COUNTRY OF ORIGIN: Texas,USA
PARTS PREFERENCES: Mm well i dont know about this because it's my first build xD so I dont know how they perform just looking reviews but reading and all ASUS, Biostar, HIS, EVGA, Cool Master, ThermalTake, etc (in other words the "famous" companies xD)
OVERCLOCKING: No / Maybe
SLI OR CROSSFIRE: No / Maybe
MONITOR RESOLUTION: 1024x768, 1280x1024, 1336x1215(i think is my monitor max resolution or so)
ADDITIONAL COMMENTS:
Hello all Im new in the "world" of PC building Im looking to buy a "mid-range" or so PC(i play games but not THAT high end games, I play Perfect World, Left 4 Dead, Starcraft 2, etc).
Right now I dont know how much im going to able to spend maybe $500-1000, in other words a im looking for a budget pc.
Ok here are the parts i found and i saw in some reviews they are good so here we go:
On all parts im open to new suggestions, o and by the way the parts im going to write are almost or the same price on tigerdirect and newegg but i dont know which one would you recommend also.
1.-Motherboard
ASUS M4A785-M Motherboard - AMD 785G Socket, AM2+, MicroATX, HDMI, USB 2.0, PCIe
I found this mother board and I think is good for it's SB710 Chipset that goes with the CPU below.
2.-CPU
Well like i said above i need a budget pc but at the same time a little fast CPU.
AMD Phenom II X2 550 Callisto 3.1GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Desktop Processor HDX550WFGMBOX
3.-PSU
The power supply I think that I don't need alot of power for a midrange pc:
OCZ ModXStream Pro Power Supply - 600-Watt, Modular, Dual +12V Rails, SATA, 80Plus
4.-CPU Fan:
Ok i researched into this because I want my CPU not to overheat or be hot so i found this 2 Fans.
*CPU fan 1:
ARCTIC COOLING Freezer 64 Pro 92mm Ceramic CPU Cooler
*CPU fan 2:
ZALMAN 9500A-LED 92mm 2 Ball CPU Cooler
5.-The famous Video Card or Graphic Card or GPU or "the-hardest-to-find card" xD:
Ok this is the most tire process I ever done.
Find a good,cheap or "in-budget", Cool and not so power consuming GPU(I know maybe im asking alot xD).
I found this one but Im not THAT sure if i should get it.
I also view TONS of reviews to look if the 9800GT, 9800GTX, 9800GTX+, GT240, GTS250, HD 4670, HD 4870, HD 4850, HD 5770, etc....and I can't find one suitable or I view bad reviews about the cards so I got hopeless.
GPU Card(but i think its not the best one for a budget mid range pc):
HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
And the last thing that without it you can get in the pieces xD
Case:
i found this sweet sweet case that i found yesterday and its really cheap and cool. It's the thermaltake V3:
Thermaltake V3 Black Edition Mid Tower Case - ATX, Micro ATX, 120mm LED Fan, 4x 5.25 Bays, 5x 3.5 Bays
1.-Motherboard
2.-CPU
3.-PSU
4.-CPU Fan:
*CPU fan 1:
*CPU fan 2:
Case:
