Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound blaster audigy 2 zs optical input
Forum CPU & Components : Sound Cards Sound blaster audigy 2 zs optical input
Hello, i have an audigy 2zs sound card and im attempting to run an optical cable from my PS3 to the sound card so i can get better sound. I plugged the optical cable into both my PS3 and the Optical in port on the sound card but im getting no sound... help, please. =/
Reply to said1206
The optical input connector on the audigy can only accept 2 channel stereo PCM, you have to adjust the audio output setting on the ps3 to get an output which is compatible with the audigy.
Reply to hairystuff
I bought the X-Fi titanium from creative and ran into the same problem. It seems that to run the signal through the fiber optic cable you can't use any of the apps on the card for say speaker separation so if you use the fiber optic cable you're screwed
------------------------------ From the heart and mind of "Z"
Reply to n2it
I'm having the same concern. I was intending to transfer a digital 5.1 sound source from an HD streamer to the sound card via the optical in via toslink cable.
So you're saying the sound card's digital input (optical toslink input) can only get digital stereo? How would the digital sound be outputted? Through the sound card's analogue outputs or via the sound card's digital output, which goes to a device that decodes the digital stereo to digital surround?
How much better would the sound be if the OP did what you said as opposed to using a regular stereo cable, from PS3 analogue output to the sound card's analogue input?
"Analogue" as in either 1/8mm (3.5mm) mini-jacks or RCA jacks.
Message edited by Stealth3si on 12-12-2010 at 10:05:10 AM
Reply to Stealth3si
So whatever sound that comes out of the sound card directly to the speakers are all analogue signal, unless one plugs a digital-surround-decoding-device between the card and the speakers.
Reply to Stealth3si
There are 1652 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 1 hour ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
