Hey guys,
I recently bought an Amd phenom II x4 945 ...i had an amd athlon II x4(630)..it started showing some heat issues..so i thought of buying a better one...i got the 945 a couple of days ago....i thought my heats issues would be vanished...but it showed me more temps than the older one(630)....i don't know if its normal....this is what i am getting:
My system specs:
AMD Phenom II x4 945(using a stock fan)
Asus M2n68 AM+
4 GB ram
Palit Nvidia geforce gts 250(1 GB)
Windows XP 32 bit OS
I got another cheap fan installed to provide cooling, idle temperature is around 49 C and while gaming it reaches upto 62/63 c.
Can you please tell me if these temperatures are normal?
And yes..I am new to gaming and computing
My system specs:
Asus M2n68 AM+
4 GB ram
